unconfigure bootprelay dhcp-agent information option
Description
Disables the DHCP relay agent option (option 82).
Syntax Description
Default
Disabled.
Usage Guidelines
To enable the DHCP relay agent option (option 82), use the following command:
The following example disables the DHCP relay agent option:
This command was first available in ExtremeXOS 11.1.
Platform Availability
